lutach
lutach's Avatar
02.07.2008, 08:37 PM
Originally Posted by BlackedOutREVO View Post
While I cant comment on your speedo.... The GT is a nice speedo, and its the smoothest of novak, LRP..... IDK what advancing the timing on the speedo does, but it does give the motor more rpm (its noticeable down the back straight..)
Its a nice speedo..... But I dont own one..... And I dont plan to, but I might get one...
All other companies timing works with different motor. A motor with 12 poles does require a higher timing, while 2-4 poles will do ok with 0-5 or so degrees. I will try to advance the timing on the ESC I have to see if I notice any change in speed. Maybe it's different in these controllers. BTW the GT was made for Speed Passion and the one I have is from the company that made them. The difference is that the one I have handles 4S lipos and has a 120A cont. and 720A burst. You can get the GT cheaper at www.rcmart.com if you do plan on getting it.
