BlackedOutREVO
02.07.2008, 08:54 PM
I know if you run a novak esc, with a orion motor, and then swap to a LRP with the same batt, gearing ETC the LRP is faster, the LRP has more timing then all the other speedos, and then the GT has programable timing, so you can use a ton of timing if you want to.
I know yours has higher specs, but in my touring car, what I want (and everyone else on RCT) is a super smooth speedo, having a speedo that can handle 2 times the voltage and all that is useless.... You can run more then 2s lipo if your really racing, so its kind of useless you know? Im not saying either one is better, its just the GT is proven to work extremely well, and thats what they want
And I can get the speedo even cheaper then that =) Good old racers discount
