Originally Posted by lincpimp
The neu moors will mount up without any problems, as long as they are smoth can models, the finned versions are too big around to fit. Any jato spur gear will work with a 32p 5mm bore pinion. 0.8mod is the same as 32p.
If for some reason you want a feigao 12s I have a used one with about 12 runs on it. It would be a great motor for 4s in a rustler. PM me if you are interested.
so i have been doing some research on the Jato spurs, it seems like they are available in 54-58 tooth models, I presently run a 83 tooth, I am planning on gearing up from where I am at now so I have been lookin at the torque of the Neu motos I have been lookin at, earlier in the post it was suggested on going with a 1509/1.5y would this motor have enough torque, would it be better to step up to a 1515/1y and would a 4 cell Lipo be enough to power it
