jordan...
one.five.two.seven
02.08.2008, 05:45 AM
ok, so i've done some sniffing around and i need some opinions. Which do you think will give me the best performance seeing as they're all roughly the same price.
Thunderpower eXtreme V2 5000mah 3s packs (Max continuous discharge 25C, Max burst discharge 50C, Max continuous current 125A, Max burst current 250A): http://thunderpowerrc.com/html/extreme-V2.html
Flightpower EVO 25 5000mah 3s packs (25C 125A CONTINUOUS, 50C 250 AMP BURSTS DIMMENSIONS: 167MM/48.3MM/26.8MM): http://www.flightpower.co.uk/index.a...p^currency=USD
Flightpower EVO 30 4500mah 3s packs (30C 135A CONTINUOUS, 60C 270 AMP BURSTS DIMMENSIONS: 165MM/46MM/25MM): http://www.flightpower.co.uk/index.a...p^currency=USD
i'm kinda confused because i can either get a higher mah, or larger um... "C" values (excuse my noobness) for roughly the same price
thanks for all the help
jordan
