bluonyx
02.09.2008, 09:20 AM
Well I got the LST shock conversion kit installed and it was a chore. In order for the shock to clear I had to remove part of the upper arm and drill a new mounting hole in the lower arm. It looks pretty sweet and I did a drop test from the the workbench to the floor and no more slapping the pavement. It doesn't even come close to bottoming out. The tires also clear so no rubbing there. Good thing because I forgot to check that when I drilled for the new holes.
Can someone from FLM answer a question though. What was the LST Shock Conversion kit setup for? (FLM arms, stock arms, RPM arms, etc...)
Here's the pics:
