02.09.2008, 02:42 PM
if this is any help
Differential Ratio: 2.8461538461538462
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 1
Pinion Tooth Count: 1
Total Voltage: 29.6
Motor KV: 270
Tire Diameter (inches): 5.75
Tire Ballooning (inches): 0
Motor Current Draw: 70
Motor coil Ω: 0
Spur/Pinion Ratio: 1 : 1
Total Ratio: 2.84615 : 1
Tire Circumference (inches): 18.06 inches (458.83 mm)
Total Motor Speed: 7992 RPM
Vehicle Speed: 48.03 mph (77.16 km/h)
Effective Speed Rate: 1.62 mph/V (2.61 kmh/V)
Estimated Adjusted Speed: 45 mph (72 km/h) - 6% loss
Effective KV Value: 270
Motor Torque: 1.83 ft-lbs
Final Torque: 5.2 ft-lbs
Final Power: 2072 watts (2.8 HP)
