ssspconcepts
ssspconcepts's Avatar
02.09.2008, 10:21 PM
Originally Posted by Nautilus View Post
So I go to mount my Neu 1515 motor to my new Emaxx and it turns out the mounting holes on the motor are not spaced far enough apart to get the 2 screws in at the same time. The motor holes on the stock motor plate are too far apart for the Neu.
I imagine people are not using just 1 screw to mount the motor, so what's up? Did I buy the wrong motor? (I did buy it from a boat place).
Not sure I understand...I have two Emaxx trucks with Neu 1515 motors and they work fine with the stock motor plate? Sounds like your Neu may have a propeller (for aircraft) gearbox attached...or they did not send you a 1515 series motor....but even the 1509 and 1521 series should fit?????
