rschoi_75
Certified Spaceball
rschoi_75's Avatar
02.10.2008, 06:34 PM
The esc can, but I don't think you need an XL motor in the DST. Its 1/10th scale, so you could probably get away with running an "L" size motor of higher kv. On 4s, it could probably do 60mph. You can check out the rcm ext. Crt.5 set-ups and the HB lighting 10 set-ups around here. Those are pretty close to the size and weight of the DST.
rcm xt8
rcm xb8
rcm crt.5
