Thread: Compro 22418
BashOn
02.11.2008, 02:35 AM
Originally Posted by AAngel View Post
jhautz,
All of my Compros do the cutoff thing. I've been pounding away at getting an 1/8 scale parking lot racer together and am very dissatisfied with what I've wound up with.
I am now running with no overcurrent protection at all and consequently, no low voltage cutoff. The 30C Neu battery seems to be doing fine in that it barely gets warm.
I was running my buggy on 4S with a MM esc, Feigao 8L motor and 18/44 gearing and clocked my buggy many times at speeds of 63 to 66 mph, using a Bushnell gun. The heat was getting to be a problem though, so I "upgraded" to a Compro 22418 and Neu 1.5d (2700kv). Same buggy, same gearing, same tires; just different esc and motor and I'm now running the 5S pack. I should be going faster. The fastest speed I'm getting now is 52 mph. Talk about an $800 let down. I was doing better with the $135 MM and the $80 Feigao on a cheaper battery than I'm doing now.
The weekend before last, I actually had people backing out when they found out that they had drawn me to race against. Last weekend, I was knocked out in the first round. I'm going back to the MM and Feigao on 4S.
I'm thinking that I need to sell this 1.5d.
So...how hard can you push a Feigao motor anyway. Do you guys think that it will explode on 5S?
It is definitely an issue with the 22418 that is causing your slower speeds. I am having this same issue with mine. If you use the "Reduce RPM" setting you aren't getting the full power, the controller is limiting the output because of the problem with the LVC. Race mode works as others say but there are the problems that come with it.....
I am not too pleased...
Have you solved your issues?
