bdebde
That's All Folks!
bdebde's Avatar
02.11.2008, 12:02 PM
It may just be the MGM, others have still had trouble with good batteries too on high powered setups (that 1521 is going to pull alot of juice). If it works OK in "reduce rpm" mode I would just run it there, it will still cut off if the voltage gets too low, and you will know it before then because it will really start lacking power (reduced rpms) before it gets to that point. I run the same accel setting and" reduce rpm" mode with no problems on 6s with 1515 2.5D.
What kind of max amps reading are you getting?
