sikeston34m
sikeston34m's Avatar
02.11.2008, 07:59 PM
The 1200kv motor is an 8 pole to, so the lower rpm and lower pole count would be easier on the esc. Do you think this size motor would be powerful enough to move the revo around? I know that the 10 pole would have more torque than the 8 pole motor, but is it a big difference?
IMO, the 3026 1400kv has advantages over the other ones.
Higher kv, more gearing options that are readily available for inrunner use.
The built in cooling fan. This isn't an option with alot of outrunners.
25mm motor mount spacing - it's compatible with most mounts.
It has the highest continous amp rating. It's tough.
