rchippie
rchippie's Avatar
02.11.2008, 10:53 PM
Originally Posted by GO-RIDE.com View Post
I tried the white springs, but at my track the car flipped over too easily. The chassis did not roll properly into the turns and instead would flip over if I caught a bump in a high speed corner. I've since removed the rear sway bar (never ran the front) and the car was even better. Now I might be able to run White F & Blue R and still get good stability in the corners. Without swaybars you can run stiffer springs for jumping and still get the chassis to lean for cornering.
I would think a 5000kv S can on 2S would be fine with truck tires and geared 12/46. I ran my 6400kv Novak on 2S with truck tires and the same gearing with very good results and only warm motor/esc temps. I also ran it with 13/46 gearing, but it did not reach full speed by the end of the straight and developed a bit more heat, so I went back to 12/46.
I think the gearing i have on it now is going to be okay. Because im using proline truck size street tires (road rage) & the motor runs cool, & i dont think the truck bowties are that much taller.
REAL MEN RUN BRUSHLESS
