Originally Posted by BrianG
That would lead me to believe that the LVC on this is too sensitive and is responding to the very brief dips in voltage during high current bursts. MGM ought to add a little delay to the LVC circuit/algorithm.
Does the MGM have an option to increase punch control? That would pull less current from the battery, which would keep the voltage from dipping to the LVC threshold as easily.
It has accel setting from .13 to 3.0 sec (basically same as punch control on MM). Higher settings help, but then you have no wheely action and lame acceleration.
