Originally Posted by lincpimp
I can say that the revo slipper is pretty tough. If you are going use it for acceleration limiting like 10th scale it will wear quickly. But if you are using it for gear/drivetrain protection you should be ok (slipper set reasonably tight). I have metalman's old revo with the slipperential and it works fine for me. I am actually going to hold off on my other revo project until the center diff with the integrated slipper is released. That looks like the most promising method to me!
Thanks for the input. I'd like to be able to use that new slipperential, but I fear that the lack of extra spur gears/gearing options could cause a problem for me. I may just hold off to see how durable/how well it works though.
