sikeston34m
sikeston34m's Avatar
02.12.2008, 08:40 PM
[QUOTE=lincpimp;148744]HAHA
That think will fly. I can't see the supervee motor being as powerful as one of those axi motors. You should easily get that boat over 50mph, which will be ridiculous. I hope the boat can keep up with that kind of power. My supervee's hull is completely out of the water at 42mph, I really can't see it going any faster and still stay upright!
Do you have the boat yet? You might be able to get away with the sidewinder esc, it is half the cost of the mm, just not sure if it is 4s capable? You can set the lvc to the same values as the mm so it should be good for 5s! I got mine for 65 bucks from tower, that 130 for two and you may be able to get the axi motors cheap too. So far my sidewinder runs cooler than my MM did in the xxx-cr. Not sure why, maybe the heatsink is on better?
I have two MM escs now, but one of them has issues I think. I may send it in for repair. It will still run a motor, but I hooked it up to a Feigao 6xl one time and seen some smoke come out of it. So, I don't think I can trust it.
I've been looking into how to build a watercooled motor plate. I'm also putting some thought into how to water cool the esc's. I might go with something other than the MM's. I'm not sure yet.
I've been tempted to put the good MM I have in the E maxx. With the new firmware update, it just might do a pretty good job. Whatcha think?
