Thread: mamba 25 on 4s?
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
02.13.2008, 12:30 AM
Do you have dirty or loose motor to esc connectors? Try hard wiring and see if that helps. Or maybe your deans connector is dirty?
It's possible one of the connectors is bad. It has done it from day one so I doubt it's dirt but it could be a bad solder joint. The motor connectors look good though as I checked those the other day and the deans is new too.
