magudaman
02.13.2008, 04:08 PM
Pulling a Xl motor off would be a nightmare but I put a quarter in there for you.
So I finally got around to taking some photos of the motor this last weekend. This motor is really awesome. Huge 10 gauge wire running inside along with hall sensors and what looks to be a thermo sensor inside too. The full finned unit weighs in at 10.4 lbs, so it not exactly light weight. I also got a chance to run the motor on the mamba max and it works great. It seems to have a lot more poles or something because I couldn’t get it to cog. The peak current I saw at 16 or so volts input was about 10 amps. That was after several full throttle start I felt I didn’t want to push my luck too far and put everything away, but not before taking some more photos for you guys:
That last one is not the actual bike I am going to use but my normal mountain bike. I am hoping to find a bike that with at least 5 or more inches of travel. Thanks for the help guys!
