Thread: Schulze
lutach
lutach's Avatar
02.14.2008, 03:14 PM
Let me explain what happened . I found a nice dry spot to run my MBX5T. I was going to run it until my 2200mAh packs didn't have more juice in them. Everything was running very cool since it was 38 degrees and you can also see in the graph I stopped a few times to make sure nothing was over heating. I did a feel full throttle passes and on one pass I slammed on the brakes and did a nice little slide. The truck rolled backwards and I applied some throttle to get it rolling again and smoke . That's when I didn't hesitate and went running towards the truck took the body off and unplugged everything. The flames happened very fast and you can see it almost burned the body and the wires from one of the packs. The Velcro straps melted in a couple of spots. Man, I was loving this controller as all I heard from others was the horrible stories of it catching on fire. So if you have a Schulze and your vehicle rolls backwards, don't hit the throttle. Wait until it comes to a complete stop .
