02.14.2008, 07:45 PM
1. Switch on transmitter, move throttle stick to top (on trigger transmitter press full trottle)
2. Connect battery pack to ESC, and wait for about 2 seconds
3.“Beep-beep-” tone should be emitted, means throttle range highest point has been correctly confirmed
4. Move throttle stick to the bottom, several “beep-” tones should be emitted, presenting the quantity of battery cells (on trigger transmitter release trottle (dont press brake- just in middle position))
5. A long “Beep-” tone should be emitted, means throttle range lowest point has been correctly confirmed
