rschoi_75
Certified Spaceball
rschoi_75's Avatar
02.15.2008, 01:27 AM
Thanks. I installed the cap on the battery leads, as close to the board as possible. I didn't want to mess with castle's solder after reading what Bernie posted, so I just cut away some of the wire housing near the base.
I got in the covers from mike today, so I was able to finish up the install. The neu is a real nice motor. This is my first so, I'm very impressed at its quality vs my other brushless motors.
edit: hey guys, I got a quick question for the neu owners. Are your motors really loud at start up? Mine is extremely loud at start-up, but then gets quiet as the rpm's go up. At first I assumed it was just my mesh, since the noise comes from the pinion/spur area. But after checking it, I found it was fine. The buggy runs very smooth at both low and high speeds (powerful too!). Nothing is binding, warped, or loose, and everything runs fine. Its just very loud at the start. I can't seem to figure it out. Anyone got a suggestion?
ID:	4039   Click image for larger version
ID:	4040   Click image for larger version
rcm xt8
rcm xb8
rcm crt.5
