83gt
02.15.2008, 11:23 AM
BashOn,
Thanks for that address. You had the problem with your MGM and a bit of white smoke, yes ? Mine did exactly the same. It worked find for quite some time, aside from the "lvc issue" (turns out, LVC is not the problem), and strange issues with freewheel setting. I changed it into race mode, and ran through a pack with no problems. I was heading out of town for the weekend so I charged the lipo's to a safe storage voltage and left everything disconnected. When I got back into town and topped off the batteries, I got everything all plugged in. Just before heading out to run, ppppffffffffffffftttt and a good bit of white smoke.
As it turns out, I found the controller still worked but with no BEC. I had to run it with a reciever pack or UBEC. It worked fine that way for about a week, and then it burned some fets. Bummer.
