Originally Posted by lincpimp
Did you run the 8 turn on the sony cells or your lipos?
Glad to hear that it works well, and the temps stay in check.
I ran the 8 turn on the Sony Cells yesterday afternoon and just ran it on a Firepower 4S 5000mah 20C setup.
Runtimes are about the same with both battery setups.
I like how the truck handles with the lipos better. A little less weight does make a difference, especially in handling and jumping.
I am very happy with this setup. I believe it to be "track worthy" now.
Got another Tower Hobbies order on the way. I put together everything to do the two speed kit with. While I was completing the order, the 13 tooth idler that I had on MY list, suddenly went on backorder. Ugh!
I completed the order though. I have a couple of complete transmissions in it for the New E maxx.
My next new project will be eliminating the slipper and going Direct Drive to input shaft with an outrunner setup.
If I can make it fit, I'm going to install the AXI 4120/14 turn!
It runs very cool and at 660kv, it should make for a Wild setup on 6S. Even on 4S, it should perform very well. It will be more of a top speed setup.
