jordan...
one.five.two.seven
02.16.2008, 05:53 AM
Well im in Australia so i don't think location makes a huge difference
If the LMT motors are 36mm that means that they can be used with the RCM heatsink right? Is anyone using a LMT with a RCM heatsink? If so, what length sink do you use? (eg. XL, L etc.)
lastly, i entered:
22.2 volts, 60 amperes and 40,000 rpm, into the motor chooser and got a 1950/7
22.2 volts, 60 amperes and 50,000 rpm, into the motor chooser and got a 1940/7
22.2 volts, 60 amperes and 60,000 rpm, into the motor chooser and got a 1930/8
i'm not too sure what seems to be the best option Do the rpm's make a big difference in performance, both acceleration and speed, and also efficiancy
thanks
jordan
