tashpop
02.16.2008, 08:47 AM
I wonder what happened to the KB45? Have you ran any tests on it?
Got a volt meter handy?
you're a wonderful person, just a day late i broke out the meter and tested the motor and i couldn't get any readings from any of the wires. i tested my other working kb and got a reading. so i started messing with it and long story short, the 4mm plugs weren't soldered worth a crap. the motor seems to be fine. i could have saved some money but all well, i got 2 new motors to play with now. i should have known to check that because i now remember soon after i started using my first kb motor it started cutting out and ended up being a bad solder job on one of the plugs. lessing learned and now i'm passing the word. redo the motor ends on kb motors. their solder falls apart and doesn't pass current well.
Current Projects
CEN GST Mgm 22418
castle 1717
6s lipo
Losi Aftershock
Infinite 160a esc
Motor Not sure yet
