Originally Posted by Nitronaught
Those arms, Flex Tek's right? Well as the name Flex is definately inherant with these styled arms.
Are you expererincing any excessive hing pin bending? If so I saw a guy make a plate, used a slightly longer hinge pin and captured the pins. Stopped beding ti pins ever since.
Nice looking setup. What do you think it's gonna weigh fully loaded?
I did something similar with my FLM Maxx w/Flex Tek arms to stop the hinge pins from bending....no problems since.
Not sure about the completed weight...I am going to use Axial Oversize beadlock wheels so it will be a little on the heavy side. Originally I was going to go with the CF chassis, but then changed my mind and decided to go AL.
