cart213
cart213's Avatar
02.17.2008, 07:36 PM
Originally Posted by wallot View Post
u put brake servo on channel 3
you mix channel 2+3
you set channel 2 BR EPA on radio to 0 (so ESC does not do anything when u push brake)
you set channel 3 FR EPA on radio to 0 (so nothing happens when you push throttle)
and on ESC you either disable braking if possible or set it to lowest setting
of course you will loose reverse.
good motor/ESC can stop 5kg truck - my Neu + MGM can stop my maxx without any issues and i have to have brake EPA set to 75% as anything higher is just too much
You don't have to loose reverse with mechanical brakes if the nitro version already has reverse. I used to have a brushless MGT with mechanical brakes, and I kept the 3rd channel for reverse. I didn't have to do any channel mixing, either.
