potreinas
Thumbs down 02.17.2008, 08:29 PM
Originally Posted by hobbimaster View Post
Sparky, Those EPA settings you posted did the trick! I set my new DX3R EPA to 120% forward and brake, and 9% on the ESC for neutral settings. Now when I let off the throttle it will coast like it is supposed to, not brake sometimes like it was. Drove me nuts trying to get rid of the erratic behavior!
My problem is with unregular aceleration with some incontrolated brakes, I tryed more than 50 different configurations, and I have some issues, If I do some 100% forward and neutral I have no problems, it's very smooth like my quark 125b, ¡¡¡¡ BUT !!!! just when I brake or go into reverse... it starts doing the rare cogging or not as smooth as before braking, with some involuntary braking. to not have this problem I can power off and restart it, and it works well until not breake is used.
If I put freewheel in NO, it just run well, but.. the motor brakes at the same time I'm letting the throttle to neutral! and I don't like this.
My actual configuration is :
jammin crt with 43/10 front/rear diffs
46T spur 14T pinion
6s1p A123
neu 1512/2Y
tests without wheels (on the air)
Controller Name 12018-3 CARs
controller version: 3.14 (bought 1 month ago)
last change: 11/01/08
poles:4
gear ratio:1
type model: <=|=>
brake: light2 / 0.26
acceleration: 0,26
timing:automat
race mode
batt type: nicd (to use lipo and a123 without reconfiguration (beeps)
range neutral: 9%
automatic correction of neutral: NO
freewheel: YES
I need HELP.
Now.. I prefer my super smooth quark 125b than my mgm12018,
ah, when I use my align 600XL... the involuntary braking when you let the trigger into neutral is awesome, it breaks my plastic spur gear tooth.
someone want a little used mgm 12020???
note: sorry about my bad english
