02.18.2008, 12:13 AM
Arct1k, maybe a neu 1509, or 1512 if it will fit. Go for a higher kv, so you can spin it faster than 40k rpm and then have lower gearing to make up for less torque than a larger motor.
How much space do you have? Maybe even the l can kb45 motors? I have a 10l that is shorter than a xl feigao, looks to be able to fit in the gas tank location. That was my plan with the lsp, and put a pair of 5s milwaukee cells on either side in the rear.
