Sparky
Sparky's Avatar
02.18.2008, 11:30 AM
Originally Posted by hobbimaster View Post
Sparky, Those EPA settings you posted did the trick! I set my new DX3R EPA to 120% forward and brake, and 9% on the ESC for neutral settings. Now when I let off the throttle it will coast like it is supposed to, not brake sometimes like it was. Drove me nuts trying to get rid of the erratic behavior!
I had posted before that I run in NiMh mode and I really didnt know if my LVC worked correctly. I ran a test to see if my LVC would act like some are reporting on this thread. So I set it at 4 cell, and Cut-off on the ESC. Then put my ol Orion 15C 4800's and had a go. I must report it didnt cut out at WOT, and I did try to open her up alot to create this LVC, or over current protection kicking in like MGM is suggesting. It ran absolutely fine, maybe mine has newer software 3.12 I believe, bought it in Jan of this year. My gearing is conservative at 20T pinion and stock 68T spur. I'm just wondering I were to go to a 24T pinion and run it harder if it would then exhibit the same cut-out. Dont know, Just makes me wonder if the problems some are having can be fixed by a gearing change, instead of shipping it off to MGM for a possible lengthy return time, and absolutely no guarantee it will solve all the problems.
If it isn’t cutting out on the 20T you can always try a high gear. The gearing is best set by the motor temp. Most motors should stay below 165F after a run. You can keep going up on your gearing until you reach this point.
