Originally Posted by E-Revonut
Will a stock revo slipper clutch fit on an original e-maxx tranny? What needs to be done? Are there mod 1 gears available for that set up and can I get mod 1 pinions with a 5mm bore? Or just use the stock revo gears 0.8mod if there are 5mm bore pinions available in that. I wanna order everything at once and I'm waiting to find this stuff out b4 pre ordering my new 5mm rotor and endbell from novak
I don't know about the clutch/emaxx stuff but you can get Mod-1 pinions from towerhobbies (century motor gear) do a search. And rc-monster sells some too. Tower sells down to a 9t mod-1 5mm pinion.
You can also get the 5mm to 3mm reducer. Use smaller motor shaft with 5mm pinions.
