Countryhick
02.19.2008, 12:50 AM
I can't believe it. I just received my MGM 16018 speed control and I'm having trouble programming the basic transmitter setup. I have a Futaba 3PK radio and use a Futaba R203HF HRS receiver.
I have tried all the suggestions I can find and still nothing. I can report that when in HRS mode the motor will continuous beep...beep...beep etc after holding full throttle and the switching on the speed control. I have tried reversing the channel but still get the same response.
When I switch to either PPM or PCM mode I get no recognition from the speed control or motor. I have tried reversing the throttle channel in all modes and still nothing. I have even tried to on hold the throttle on just slightly to see if it makes a difference and nothing happens, no beeps, nothing....
Maybe I should find a standard (non HRS) receiver and try it. (wish there was a crying smiley)
