Countryhick
02.19.2008, 03:48 AM
Originally Posted by gixxer View Post
the 606i is limited to 50watts. you are going to want either the 1210i or 610i.
+1 You will find due to the low output of the 0606i (50 Watts) you will only be able to charge a 6s pack at a max. of 2 amps = slow.
If you go for the 1210i (max. output 180W or 7.1 amps @ 6s) or the 0610i (max. output 250 W or 9.9 amps @ 6s) = fast charge.
I have the 0610i and luv it!!!
Check out this page HERE and have a go at Brians charger calculator.
Hope that helps
Cheers Andrew
P.S. Just be aware that you will need a good power supply to feed the later 2 chargers. Brian has also added a power supply calculator to the page I have linked be sure to check it out as well.
