Finnster
KillaHurtz
Finnster's Avatar
02.19.2008, 05:10 PM
And you don't have to run a wire all the way from the receiver, just wire it to the battery wires where they attach to the circuit board on the MM.
You can actually do the same thing w/ the 5V fan if you are using the BEC. If you are using 4S/external BEC tho you are prolly better off using a 12V. The only bad thing is that the rpm is not constant, but its not a biggie, All-e doesn't have them in stock anyway.
