sikeston34m
sikeston34m's Avatar
02.21.2008, 06:43 PM
This is good to hear, I would think that high start power should help, I have the MM set to that way for my Plett maxximum in the crt.5
Not sure about the timing though, do outrunner require more timing advance?
I would have thought that since they run slow they would need less timing.
The KMS equal. says 20-30 degrees of timing. MM only goes up to 20, so that's where I put it.
I pmed Metalman about a possible "hook-up" on the KMS motors.
I guess the lower kv versus inrunner motors doesn't make a difference. I know the phase switching via esc is alot higher per revolution. From what I understand, the timing is just the precise point of phase switch in the rotation.
