bdebde
That's All Folks!
bdebde's Avatar
02.22.2008, 04:23 PM
The only problem I see with the 2200kv motor, is gearing low enough in some setups due to motor running into something before a small pinion meshes. Other than that I have no problem running 50,000 if the motor can handle it. I run Big Maxximum (2300kv) on 6s no problem, and have even run a 7XL (similar kv) on 6s as well. Of course the XL will get much hotter than a better motor, but it gets no hotter than it did on 4s!
