shawn197
shawn197's Avatar
02.23.2008, 12:01 PM
It seemed to run very well on a race track until I had a problem with the motor. I used a Feigao (I wasn't quite sure about the exact model of it because it came with the Gorillamaxx G2R chassis that I bought used. And I forgot to ask the person about it) on 14 cells (Maxamps 4200 Mi-mh). And the gearing that I used was the stock gearing of 68T spur and 19 pinion. It has a lot of neat functions. It provides 64 different settings of traction control and overdrive function which gives the motor very high output. There are 4 new brake modes with 100 steps in each mode including professional ABS brake, Artificial Intelligence automatic brake, and semi-auto brake. It also has 32 step voltage limit function and internal multi-protection function which allows us to check temperature, voltage, signal, motor mal-function, and setting. It seems to be more thoughtfully made than 125B because it has built-in heat sink and a fan. It basically runs cool.
  Send a message via MSN to shawn197
