johnrobholmes
johnrobholmes's Avatar
02.23.2008, 02:04 PM
Originally Posted by Sower View Post
I have no problem with the 2200 motor except on 6s. Some people may be fine with it, but I feel it's outside the motor's ideal efficiency. Especially if you're looking to race.
So I assume you are on the design team and have seen the efficiency curves then huh? So much speculation here when in fact NONE of us know jack about the motor other than KV. Knowing Castle's track record, I seriously doubt they would suggest 6s on a motor unless it runs good. If the efficiency suffers, then it will show up as extra heat when the rig is geared for the same final speed.
