02.23.2008, 08:23 PM
I was reading your sig, what did you do to get ur E down to 7.5lbs, besides a single motor setup w/ lipo. Because the AL shock towers would add weight, and the rpm Steel cvd's also add weight, especially if your still running 4WD setup.......
i have converted to 2wd, 1 shock per wheel, removed shift servo, and 7075 T6 pillow balls, TI hingepins, and i'm only down to 10lbs w/ batts
