jhautz
jhautz's Avatar
02.24.2008, 06:30 PM
I don't think it would add more power to the motor, but it will for sure help keep temps down. I did a little test of the MM internal BEC on 3s (which is within the limits according to the specs) and the bec components heated up to 180 degrees in a matter of just a couple minutes (and this is with virtually no load on them running just a 25mm 5v fan.) No matter what voltage you run the BEC will generate some kind of heat so it certainly will not hurt the esc to remove that heat source.
to make it...
or break it...
Silent...But Deadly
