drkros3
02.24.2008, 09:51 PM
check the balance on the lipo pack. Make sure you don't have a bad cell in it. If its balanced I would charge it all the way up just to eliminate the battery as a possibility.
Another possibility could be that you need to rerun the radio/esc calibration so it recognizes full throttle? or possibly did the EPA on the radio get adjusted way down? Check all your radio settings, make sure they are zeroed and then rerun the esc/radio calibration. That should eliminate that as a possibility.
If its running, just not fast enough that seems very strange. Usually when a ESC goes bad it goes bad all of the way.
EDIT: Gee beat me to it.
yah thats what i was thinking. thats why i have not tryed to swap out the esc.
also on the battery i fully balanced it and charged it back up and its good.
im running deans on the battery and bullet connectors on the motor.
i guess i well look at the settings again and see if something is out of place.
any more suggestions i want to run this thing. lol i got paddles for it and it wants to go to the beach hahahaha.
