sikeston34m
sikeston34m's Avatar
02.24.2008, 10:34 PM
Well, from my extremly limited knowledge, the brain has to have some sort of regulated voltage. An opto isolated esc does not have the current ability of a bec built it, but must have some sort of regulated supply for the brain. Time for the smart people to tell you what to do.
How about I eliminate the onboard bec, then just feed the Brain "through" the red wire from the external bec?
Sounds like I would have to keep the external BEC set at 5 volts though.
Hmmmmm..........
