MetalMan
MetalMan's Avatar
02.25.2008, 02:35 AM
Originally Posted by Sammus View Post
Lol didnt even think about that... I'm running a Feigao 9L with a Mod1 Mamba Max and (at the moment) 3s 4000mah 20C packs I made myself... looks like they will be a little big to put right on the chassis, so I'll either make up a mount to let them hang slightly off a bit, or get some smaller packs... or get a bigger chassis lol (running stock pro chassis at the moment).
My CRT.5 is running pretty much that same EXACT setup, except with a regular MM, and a CCBEC. It's geared with an 18t pinion, and the extended chassis I made for it is the same length as the RCM chassis. The 9L is a couple years old, and does just fine. The hottest I've ever gotten it is maybe 150 deg. The MM gets to about that temperature as well (no fan). Mine runs all truck tires (HPI Yokohoma Geolandars for the street, Holeshots for the track).
