snellemin
2 KiloWatt RACER
snellemin's Avatar
02.25.2008, 01:23 PM
I use a 15" kicker sub in my home entertainment system. It's power by a seperate amp. You could do the same thing with the 12" sub you have, using the plate amp that BrainG suggested. You want to build a down firing sub in a sealed enclosure. The distance between the woofer cone and the floor should be around 10-12". Putting the box in a corner "amplifies" the output some more. Firing in down onto a carpet floor works best too. Less sound reflections. If the box is stiff enough, it can be used as a corner table. If it vibrates too much, just add a marble slab on top and you gain some more output and nothing will vibrate off of it.
Ok, I said too much again..
Just use the kicker sub man.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
