02.25.2008, 02:27 PM
Some answers below.
- Am I on the right track with my selections?
They look good, only issue would be that the mm may not arm with 14 cells.
- What motor would be best suited to 14 cell use in hot summer temps? A 7,8,or 9xl?
The 9xl would be your best bet, rpm would be around 30k and it will run the coolest of the 3 motors.
- What gearing should I run to keep the heat down to acceptable levels in the 90F+ summer heat when running in grass?
Stock spur and a 22t 32 pitch pinion, you will need a 5mm bore pinion.
- Will it be somewhat faster than stock?
Should be at least 8mph faster than stock.
- Will it have plenty of torque?
Oh yes!
- How would the run times be compared to stock?
You should have better runtimes, maybe a minute or two. That really depends on the battery quality.
