JThiessen
JThiessen's Avatar
02.25.2008, 07:42 PM
you only need space to play low frequencies, no radio music has or any store bought cd's (except for bass specific cd's) play low enough to warrant that large of a room, however, a bigger woofer has a larger cone area and will play louder than a smaller woofer, he says he wants more bass than a single 12" with 285w gives him, so a smaller woofer is not the answer. A subwoofer is just a fancy air pump, move more air=more bass bigger woofer=more air moved. A plate amp is just an extra amp to only power the subwoofer. You'd still need a non-powered (passive) subwoofer. It's easier and cheaper to buy a powered subwoofer rather than an amp and a subwoofer.
You are correct, he did say "More" - not "Better"......
Smaller woofers will give crisper, more accurate and cleaner sound, especially when driven by high power. The REL line http://www.rel.net/of subs is widely considered one of the best out there, and I dont believe they have any over 10", but they are running gobs of clean wattage (true rms values) in a small space. If you want your house to shake on a budget, then bigger with less power will do that. If you want to invest in the future (if that can even be considered with todays electronics market), get a smaller high powered one, then down the road, add a second or third sub to the system. My first one was a 1XX watt Yamaha Dual Driver sub, that actually did quite well. I picked it up at a demo sale for a little over 100 bucks. Its nothing compared to what I run now, but it was a great place to start and learn what I liked in my theater.
wow,def tec! remember the bp2000's with the built in 18" powered sub? awesome......
Yes, I almost went with the BP line, but I personally preferred the crisper sound of the Mythos Line - and they fit behind our couch better for the rears.
