Originally Posted by Hickoryhead
Can you measure the clearance you have under your rustler? Please? Pretty Please??? PRETTY PRETTY PLEASE???
It may not be the same as using stock arms and stock shocks. I've got FLM A-Arm Kit FLM24800 on there along with Duratrax Evader Pro ST shocks all around. However, it's about 1 7/8" from the ground at the lowest point. My VXL with stock tires and wheels (but Losi threaded shocks) is about 1 1/2" from the ground at the lowest point.
