Serum
Serum's Avatar
09.03.2005, 07:22 PM
if you want 100 percent safety, get the conversion kit.. You could do some measurements yourself.. Use a caliper and some imagination to make it work! You can see the motor fit in Joeling his savage, so it will work.. In the worst case you need to make a motorbrace, to support the motor, but on the other hand, i seriously think that thise motormount is strong enough and doesn't need any support..
The 'orignal' motormount needs an extra hole as well, or it is likely it's angle can change due to jumps etc. With the motormount of Joeling, this won't happen..
You can adjust the motors position by using the normal sleeves in the motorplate for adjusting the mesh of the clutchbell/spur.
