Thread: Lipo questions
Hickoryhead
RC Wanna BE
Hickoryhead's Avatar
02.27.2008, 09:33 PM
Originally Posted by Jbreddawg View Post
My understanding "way back from high school though lol " Is that when you run them in series you add the two so two 2s 3000's would equal one 4s 6000 ? And run in parrallel you would get 7.4 volts but 6000 mah ? is my memory not serving me correct ? It has been more then 20 years since school !!!
Your close. To run in series you add the cells together but not the mah's. To run in parallel you add the mah not the cells. Like Sammus stated:
two 2s2p 3000 mah packs---
2s2p 6000mah (parallel)
4s2p 3000mah (series)
And of course paraelle gives you double the run time and series gives you double the power output.
Be careful about the Lipo's you buy. They are very sensitive creatures. You get what you pay for. Just because the numbers on the packs look good does not mean they will perform good. I would not suggest to anyone about getting those batteries. There are to many factors when it comes to Lipo's. You don't need to buy the very best lipo but don't buy the cheapest you can find. Like I said you get what you pay for with Lipo's. That battery might be fine on a Helo but in a truck that is bashing and crashing they may not stand up to a beating or the cells might not put out the amps your looking for. Just my 2 cents though.
NECESSITY IS THE MOTHER OF INVENTION
Emaxx Tranny slipper modification (Strobe like)
http://www.rc-monster.com/forum/showthread.php?t=9341
