skellyo
skellyo's Avatar
02.28.2008, 02:10 PM
Originally Posted by jadesportster View Post
by nut I mean the 6 sided hex fixture where you adjust the turnbuckle for toe/camber while mounted on the truck.
Traxxas makes aftermarket red/blue turnbuckles that takes a 5mm wrench. Lunsford is 6 or 6.5mm
These FLM turnbuckles are 2mm or 3 mm and nobody--- I mean NOBODY within a 6 state radius of North Carolina makes a wrench that small...
None of the turnbuckles I have ever gotten from FLM have had the hex on the shaft for adjustments. Also, unless you're really strapped for $, you're better off with another brand of turnbuckles anyhow unless FLM has started actually threading the turnbuckles with reverse threads on one end. It's no fun to have to remove the turnbuckle completely to adjust it.
