pipeous
5th Scale Guy
pipeous's Avatar
02.28.2008, 05:03 PM
Air compressors rock. I am an auto detailer by trade and used my air compressor a lot. WD40 is a good cleaner but sucks as a lube hehe (also good for removing chewing gum from carpets).
I use the hose sometimes after a muddy session. Spray with cleaner, use a paintbrush to agitate, rinse with water, blow with air then spray with nitro blast or brake clean (metal parts. helps evaporate water) then oil. I like liquid wrench because it inhibits rust and is a thin oil that lasts.
Another cool machine I like to use is a steam blaster. mine is a fairly industrail unit but they have smaller versions that would work. XS cargo here sells one for 15 or 20 bucks. they come with a trigger and heat the water. you spray pressurized steam.
My favourite air tool is called a Tornador by Auto Magic. Do a google search and check them out. there are vids on u tube as well. It comes with a cleaner. It sprays air, cleaner, has a cyclonic action which also sucks dirt into the cone when pressed against fabric. I think if you had one you'd clean your own car more often due to ease of use and possibilities. I clean air vents and hard to reach places with mine.
Cleaning has an acronym. TACT. Temperature, Agitation, Chemical, Time
Temperature because heat increases cleaning efficiency of any given chemical to the effect of for every 5 degrees over 150 the efficiency almost doubles.
Agitation is straght forward. Rub the cleaner around loosens things
Chemicals clean better than water. You can spray your auto ith a hose but it still looks dirty.
Time is leaving chemicals sit to work
To finish the plastic off when all said and done, a little furniture polish and a toothbrush makes all the plastic nice and clean again. It even cleans the bodies well including the windows
